Message Queuing is not Installed
MSoltani
Feb 2010
IRAN
Hi Friends
While I try to install PCS7 .I must Install WINCC so I should have Message Queuing but By this Alarm
"The properties of this computer were not obtained from the message Queuing server"
It was stop .Do you have any suggestion about this matter?
THANKS.
I had the same problem installin WinCC.
Go to Control panel
Open Add or Remove programs
Click Add remove Windows components
From the list select Message Queuing
Click Details
I have only selected the Common check box
then click OK
There were few other things also needed like SQL server but hope this is enough
Does any one know how to realize MSMQ queuing sending/receive from PLC to PC?
1,154
hi everyone, i have problem regarding Audit in FTV ver 12,In audit message "service disruption:<HMI server name>:<SERVICE NAME>" message logged,i...
45
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
411
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
136
I have a safety PLC AB that is stuck trying to charge the capacitor and will not do anything. No communication or anything can be done. Is there...
72
