Messaging over Plant Radio from CLX
Ga1011
Nov 2019
Georgia
Anyone have a recommendation for transmitting alarms, messages, etc...over radio? The alarms will be generated from a CLX platform above V21 and the idea is to have the signal be capable of talking over the local radio frequency within the plant. I am aware of messaging over email from a PLC but never radio freq. Thanks in advance for the ideas.
Explain more about the "local radio frequency within the plant".
Do you have serial radio modems ? A literal voice radio system ? WiFi or 900 mHz modems for TCP/IP ?
A ControlLogix/CompactLogix with v21 or higher firmware will generally not have an RS-232 port of its own, so Ethernet is your most likely transport.
apologies...The radios we use in the plant to communicate over. I will have to dig a little digger into the comms method in which they work. I am obviously a little out of my depth. Thanks
Something like trigger a specific recording on a MP3 player that broadcasts on your radio system when playing.
Not sure if a single MP3 player could broadcast multiple recordings or only one per player.
Maybe have a SCADA system trigger an audio file at a certain condition and the computer audio tied to the radio system.
The problem I see is if the radio system is in use and everyone is hearing someone would your system be able to identify it as in use and wait, or blindly try to broadcast during the existing communication?
The gold standard for remote annunciation of automation or SCADA alarms is a company called Win-911. They integrate with PA systems and campus paging, and email and SMS. If there's a radio integration system appropriate for your system, they've probably done it.
I agree that the most difficult part of any trunked or campus radio system is the half-duplex nature of the system; if somebody is talking do you want the annunciator to talk over them ? Do you have priority channels or channel scanning ?
Do you already have a plantwide SCADA or HMI system ? I've done local *.WAV files as an annunciator on an HMI, but never integrated them into a campus radio system.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
166
Hey guys. Got a strange one. Was sent to a site where the VNC access is very poor. The IT has assisted and a Wireshark report shows data...
325
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
80
Hi, First time poster, long time reader. I've got a mass flow controller device for controlling the flow of gas. It has a flowmeter and an...
276
