Method to check if UDT data has changed ?
Jimbojones
Mar 2015
NC
Hello!
I need some advice on how to check if the data in a UDT has changed, without going through each of the tags in the UDT. I use an array of my type UDT for recipe storage.
What I am trying to replicate is a simple checksum ... if the checksum is different for the UDT then what was stored, then flag the need to save the recipe.
Thank you!
You'll have to compare each element of the UDT. If it's all INTs, DINTS, or Reals, and if you trust a check sum, then add them up and compare.
If you're using Logix5K or Studio5K, you may be able to use FSC or FBC depending on the complexity of your UDT.
Within the UDT I do not know of any easy method
However you can use COP to put the data into an DINT (or INT) array and then loop through the DINT array performing your checksum or comparison
the loop can be FSC, FBC or your code
sir, while running program in codsys an error occur 'C0138: No matching 'FB_Init' method found for instantiation of FbPowerPlantControl.' how to...
95
Hi, I have a 2.2kw drive, this is a lift application and the manufacturer says to use the 87hz method. In theory I understand this but in...
879
Hi Guys, During PID Tuning by Ziegler Nichols Closed-loop method, In TIA Portal there is a Trend Tool used to determine Ultimate Period; marking...
1,889
I'm using ftview 13 with rslogix v35. I want to use a button to reset all alarms coming from process CPU L83-EP. I tried using invoke method to...
1,897
Good morning! I am looking for a clever method to determine the number of occurrences in a series using ladder logic. What I need to determine is...
1,269
