Mettler Toledo IND 560 with Micrologix 1400
Not with a micrologix specifically, but I interfaced a number of those to Controllogix platforms as well as generic OPC via Kepware.
Used AB-RIO with Contrologix.
Not sure if you can use Explicit Ethernet/IP messaging to the IND 560, but your safest and simplest bet may be with Analog.
I don't think so no, but the IND560s also support modbus tcp w/ the right option board, and the ML1400 supports that at least.
I think there is a possibility, you will need to setup your messages like so:
the last part will need to be in trial & error:
Hi all Thanks for all the replies,
I have followed the message instruction mentioned below and it work.
There is one more thing i want to know is actually i need the printing weight of Mettler. By printing weight, I mean that when a product passes through Mettler weighing scale , then Mettler auto adjusts and displays that weight on its screen.
Actually I have done this in rslogix 5000 by using message instruction. Screenshot of message instruction is attached .
Now i am doing same message in logic 500 but it getting error.
Please help ...
I am really looking forward for all of yours opinion on it.
Very funny! you didn't particularly thanking bachphi, but to the other "no I don't think so"??
Did you try to increase the receiver size in bytes to 16?
How to do that can any one give me the how to write instructions example
839
I am working on an older system where they are switching out the weigh in motion scale on a conveyor system from an AP Dataweigh to a Mettler...
1,181
Currently my company has a MT metal detector model V4 that has been down for the better part of a month. The metal detector is giving a F06-5 IO...
3,097
Hi, I have a Mettler Toledo IND780 (AB-RIO) and a SLC5/04 with a 1747-sn RIO Scanner card. I have lost the configuration for the Ind780...
2,225
I have an existing machine with a SLC5/04 processor. It communicates to a Mettler Toledo IND780 scale controller via remote I/O and a 1747-SN...
2,053
