micologix 1200 fault
simon_H
Sep 2013
NYC
Good evening gents ,
I've a micrologix1200 which suddenly faulted , I almost checked all threads here and tried all suggestions , the fault led are steady red , and I can't connect rslinx to my micrologix , I tried to press the dcom button but no response and the fault is still there ,is there any other way to clear the fault externally without the software ? or how can I regain the communication with the plc again.. your help is greatly appreciated ...thank you for your time and help .I'm awaiting your suggestions
Simon
If the Power and Fault LEDs are on solid red, and they come back solid red after a power cycle, then the controller is faulty and must be replaced.
If it were my controller, I would remove all the I/O wiring and just apply a known-good power source to make sure there isn't a short circuit or power problem.
Thank you very much for this super fast response , I do really appreciate it . And I've already done so before ,but still the same.
Looking for help to get a micrologix 1200 to send a text on an alarm signal. The message doesn't have to be complicated... one letter would work...
2,870
Dos anyone have an rss file(logix 500) with modbus rtu communication. I am trying to get some value out of an janitza ugm511 power analyser. Eg...
22
4,533
I am trying to run Micrologix on my Mac through Parallels and Windows 7. I have a AB Micrologix 1100 connected via ethernet. For some reason I...
2,852
hi; I have gotten a micrologix 1100 PLC and i am trying to connect with 1747-uic in rs 232 mode, i am using cable 1747-uic to micrologix 1100...
4,203
Dear All, I am trying to setup PID logic in micrologix 1500 LRP. but plc is going in fault mode showing major error as " Invalid value is being...
2,716
