1747-uic rs 232 mode to micologix 1100
silentcororo
Jul 2010
Chihuahua
26
hi;
I have gotten a micrologix 1100 PLC and i am trying to connect with 1747-uic in rs 232 mode, i am using cable 1747-uic to micrologix 1100 1761-CBL-PM02, but cant fint the PLC on rslings.
but when i try to connect to SLC 50/2 using only dh485 with 1747-uic rslings fint it.
need pother cable or cant conect to micrologix PLcs with 1747-uic ??
thanks in advance
Miguel V.
The ML1100 serial port would have to be configured for DH485 in order for the 1747-UIC to work. If the ML1100's port is configured for DF1 protocol then your
1761-CBL-PM02 and a USB to Serial adapter will work. Do you have one? If not the "Keyspan USA-HS19 is a good one ( see link below for one place to get one)
http://www.plctrainer.net/
hi;
how could i conf the plc to dh485 on the rslogix ???
thanks in advance
Miguel V.
You need to establish communication either thru its serial port or the Ethernet port and then change the serial ports configuration. You can do this online or down load the new configuration. But getting connected comes first.
I have a 1747 uic that im trying to configure and need a little help. I got it to acess a slc5/03 via the cat5 or rs485 but I cant get it to work...
3,901
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
406
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,299
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,436
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,252
