1747-UIC Question
Apr 2002
Just a bit northeast of nowhere
1,117
Hi Everybody!
Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter?
Since it present to the PC as a virtual serial port, I was wondering if I could get double-duty out of it.
Thanks!
TM
never tried it but...
I do not think it will work that way.
DH-485 is specific to Allen Bradley and the 1747-UIC was made to replace the old 1747-PIC.
the 1747-PIC was serial to DH-485
The 1747-UIC is both a USB to serial UART device with an RS-485 physical signal, and also a protocol converter (DF1 to DH485).
You couldn't use it as a USB/RS485 interface for an application that used Modbus or ASCII or another serial protocol.
I don't see it working DH 485 and RS 485 are completely different proto calls the same a using a RS 232 to RS 485 converter will not work
Before the UIC they had a RS32 to DH 485 converter to use on original 500 bricks
The 1747-UIC really is a two-trick pony.
The 1747-UIC will not work as a general-purpose USB to RS-485 interface.
It converts the A-B proprietary PCCC protocol commands and data transported by asynchronous DF1 protocol to the same commands and data transported by the token-passing Data Highway 485 protocol, either over RS-232 or RS-485 signaling.
It won't know what to do with ASCII or Modbus or other protocol framing, let alone the data payloads.
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,295
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
402
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,248
Hey all, first time posting. I have gotten a lot of great info from all of you in the past. I have searched the forums and google as much as...
3,455
I run PanelBuilder32 on an XP VM. A few months ago, my hard disk corrupted. I thought the IT guys had managed to get everything back but it seems...
5,955
