DH485 and 1747-UIC adaptor---cable question
Skidood
Oct 2016
Ontario
215
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232 function. For connecting my laptop to the PLC, I can use the 1747-UIC and apparently cable 1747-C13. It looks like a Cat 5 or 6 ethernet cable with the same RJ-45 type plugs. I don't have this cable. Any chance a standard ethernet patch cable or a crossover cable would work?
Straight through patch cable will be fine. Do not use a cross over cable.
Hello, I'm having some issues seeing a panelview 300micro (2711-M3A19L1)when it is wired up to a PLC (SLC503;1747-L533 SER E) and to our...
17
4,801
Hi friend..... I have a little problem with this cable.... This cable has a out dh485 with this i can setup ok.... but the other rs232 i can't...
2,532
I'm attempting to go online to a Micrologix 1500 using a p.c. without a serial port. The 1747-UIC USB to RS232 interface won't let me on. RS Linx...
5,906
I don't know if it is available yet, but I found the manual on-line. http://www.ab.com/manuals/cp/1747-in063a-en-p.pdf Tell the IT guy that gets...
2,210
Hi, I have SLC 5/03 with 1747-AIC (DH485) modules. Original HMI was PV550, this HMI was replaced to a PanelView 800 (2711R-T7T), communicating is...
1,241
