CeeDee
Hello,
I'm having some issues seeing a panelview 300micro (2711-M3A19L1)when it is wired up to a PLC (SLC503;1747-L533 SER E) and to our shop's laptop using RSLinx. The SLC has two communication connectors on it: a RJ45 and RS232 connector on the CPU face. I'm using a 1747-UIC (DH485 to RS485 or RS232)to USB adapter that plugs into the laptop via USB port. The adapter has one of two selections and is selected for DH485 to RS485 (standard cat 5 cable). The cat5 is connected to the SLC503 CPU; pretty standard. I can see the SLC via RSLinx no problem. When I hook up the PV300micro to the SLC via the 8pin mini DIN (panelview side) to the D-shell RS232 (SLC503 side), nothing happens. I can't see the panelview on RSLinx. I don't know how else to "see" the PV without directly connecting it to the 1747 adapter; and the laptop. I want to be able to talk to both the panelview and the SLC at the same time. There was no transfer of knowledge on how this was achieved before the guy that did this stuff left our shop. But thess are the components I was left with so I know it has to be possible somehow. I was thinking a certain communication pass thru on the SLC CPU was impeding communication through the SLC to the adapter. I tried looking up manuals for this stuff, but finding helpful info on this particular subject has been near impossible . Any ideas what I could try?
