I've got a Micro 1200 setup as a Modbus Slave on an MDS 9810 radio. I haven't had a communications drop that I've seen & no "kiss of death" errors, but when I'm online with the PLC I have noticed in the channel status file that sometimes I get a "Link Layer Error Code 5". I also have other PLC's programmed the same, & also on radios but no errors.?.?
Could someone enlighten me as to what this code is?
I did see something in an AB Manual about "Bad parameter".
Is this correct & if so why aren't the other PLC's showing this as well? (That last one may be a stupid question but there it is anyway.)
As always, THANKS for any & all help.
