Micro 830 RTC Timed Events
spatricks
Jan 2013
oklahoma city
I have the Allen Bradley Micro 830 and I am trying to setup a daily and weekly event that occurs at a certain time. It looks like the Micro 830 supports and external RTC module. I do not have that module and need this functionality without purchasing one. Is there anything else I can do to trigger on these time events based on the current time?
how are you going to set the value or check the value?
Are you using a HMI?
the altenative is to setup a one sec. Pulse. then setup multiple counters to stage the switch point.
but the only way you will see this is if you are interogating the PLC.
Hi all, I have a AB Micro 830 - 2080 LC30 24QBB w/ 2080 MEMBAK RTC plug in module installed. I am setting up a program where I need an output to...
2,757
Hi Guys, Is there any way to get the real time clock datafrom the PV300 to the Micro 830 ? I have figured out how to communicate from the PV to...
3,044
Hello friends We communicate between Micro 830 and a card that control DC motor via modbus RTU. We do not have any problems in communication. But...
1,524
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,562
Customer has a Micro 830 (2080-LC30-16AWB) and a Panel View component C200 (2711C-K2M). They want to add remote connectivity. I was thinking of...
2,699
