Getting RTC data from PV300 to Micro 830
LVarga
Jul 2013
Brussels
Hi Guys,
Is there any way to get the real time clock datafrom the PV300 to the Micro 830 ? I have figured out how to communicate from the PV to the 830 but I don't know how to trigger this action. Or maybe I should try to read from the PLC the data from the PV... but I don't know how. I am using CIP communication.
Any idea would be very helpfull.
Thanks,
Laszlo
I found Knowledge Base Article "456864 - Micro800 Quick Start Real Time Clock (RTC)" it talks about about the Memory/RTC module. Take a look and see if it helps.
Here is another KB Article "494822 - Working with 2080-MEMBAK-RTC plug-in module" It has even more info
Thanks a lot. Actually I have found how to do it, the PV300 has the RTC buit in and I could link the data to the PLC directly.
The problem is in case of power failure, the PV will looses the time because it has no battery.... So I may need to buy an extra RTC plug in for the 830.
Here is what I have done. The hour and minute variables are added to the Global connections tab and also in the External tabs are linked to the controller (Grimbergen in this case).
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
58
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
84
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
616
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,418
Good morning guys; Im new at AB plc, and i just need help about a table or a list called something like "exchange data table" in French it is...
779
