Micro810 CTU Reseting
jw1591
Mar 2013
Indiana
I am using an Allen Bradley Micro810 to count cycles on a machine. After 100 cycles a warning light will come on to have maintenance performed. Problem is I was unaware the CTU block resets itself with every power loss. Is there a work around for this or a setting to change to have it retain the CV value?
welcome to the site
Please Zip up a copy of your program we will look at it.
For some reason I cant attach a file or image. If I figure that out I will post one of them later. I am using Connected Components Workbench and an Allen Bradley Micro810 with firm the firmware upgraded to 2.011. In the program I have a CTU (count up timer) that tracks cycle times. The issue is when ever the operaotrs drop power to the machine for LTV reasons the CTU looses its current count value. Since LTV is performed often the counter never reaches it setpoint and the maintenance light never comes on. Any suggestions would be greatly appreciated.
could you move the counter value into a register and then have a first scan bit write the value of the register back to the counter? I havent fooled with the micro so I am not sure if the first scan bit is available.
In this project I wanted two pumps to alternate between lead and lag. The controller is a Micro810. I'm using a counter to dictate whether pump 1...
1,109
Hi, I'm experienced in Studio 5000 / ControlLogix but have a small project to do in a Micro810 with CCW and something is driving me nuts. I want...
4,043
Hello everyone I'm working on a project where i have to use the pid instruction (ipidcontroller) in my AB micro810 plc to control the water level...
2,594
I am switching from a Pico controller to a Micro810 plant wide, is there a way to transfer the programs from Pico to the Micro810 without having...
2,417
