Micro820 CCW Tag Retention
PLC Pie Guy
Jun 2013
Halifax
1,144
Morning All.
First off, I want to say thanks to the folks that helped me get this project going. The first one with CCW and Micro800 line. It was a head scratcher for sure. Iv pretty much got it covered now but I do have a question about my tag values not remaining through a power cycle or download.
I have many values defined in tags that are LINT, BOOL, and UINT that do not seem to keep values. Everything gets reset to 0.
Something simple I must be missing here.
One other question, does the developer edition allow online editing? I don't have it yet but I should in the next few hours. Disconnecting and doing the build/download reminds me of working with an old micrologix. Since this is my first project you can imagine how many times I have had to build and download. ughh.
Hey all again.
So , I have the values retaining by checking the box that says "Retained". I kind of remember this sort of thing from TIA Portal way back when.
This being the case, I am faced with another challenge. I will have on my HMI screen, value input fields. I want these values to be saved when the HMI button "save" is pressed. At that time I will MOV or COP (haven't got that far yet) my HMI displayed values to the appropriate tags within the PLC. What I am questioning is how to save these values to the tags. Would I want to have these tags "retained" boxes checked or not before I build my project? If I click the retained box with a random value in the tag will it retain the new value entered on the HMI or the "initial" value of 0?
FYI: I am now running the developer edition of CCW V9.01.
Apologies for so many questions today but this has been an interesting week with many head scratchers to work out.
Thank you
hey guys, so I've been stuck for a couple of days trying to connect to a Micro820 version 12 using CCW version 12. I see the IP using "Discover"...
1,671
Hi, I started my journey with Micro820 and I have to read input status address 10001-10010 from one device via Modbus TCP, everything works fine...
1,196
Hello all. Is there an easy way to perform a compare for 2 versions of a Micro820 program in CCW?
1,283
While creating a project, I've discovered an issue trying to utilize related instructions from others in different programs. It seems as if if...
2,053
