micro820 fault - HELP!!
cdnrookie
Apr 2013
Canada
112
We were trying to connect our proface and micro820,
I was just downloading the new program into the 820 when there was an error with the download and the program froze.
Waiting patiently for over half an hour, I finally had enough and quit the program, rebooted everything and noticed the controller was flashing red
micro820
flashing red fault indicator, NO OTHER INDICATORS ON!
I cant find this scenario in the manual
create a new simple one rung ladder, build and download. CCW will ask if you want to clear the fault, say yes, continue the download.
Now go back and double check your original program and make sure it builds OK.
Just want to make sure we're on the same page. You are using an Allen Bradley Micro 820 PLC - is this correct? If that is so, then you have to use "Connected Component Workbench" as the programming software. If that is not the case that's probably the reason the PLC is Faulted!!!!
CCW is free from Rockwell Automation.
There is no way to clear a fault with out CCW is there?
I have a customer with a faulted 820, and no remote access. I would prefer not to have to go out there.
Depends on the fault and how the Fault Override was setup under controller properties. If Fault Override was set to Clear Fault, it should at least try to clear the fault on startup.
You can actually do things via the SD card, like clear the fault.
Create a text file called ConfigMeFirst.txt
Try putting the following in it:
[CF]
[END]
Save it on a SD card power up the Micro820 with it inserted.
You can also set the IP address, save the project to SD, restore project from SD.
Hello all! I come asking if anyone has had this situation. I have a Micro820 controller that sits idle for some long periods (I use it to count...
1,347
I have recently started using Allen-Bradley’s Micro820 PLC for simple machines that only have a couple dozen I/O and uncomplicated programming...
5,465
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
855
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
181
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
920
