Micrologix 1000 Analog
Bob O asked "What is a 4-20 mA simulator?"
If you do any process control this is an essential device. It is a signal generator that lets you put a controlled current signal into a loop. They run anywhere from a couple of hundred dollars to over a thousand, but the cheap ones are all you need. Just make sure it has the ability to be either loop powered or self powered, and that it has a potentiometer to let you vary the output steplessly on up. In a pinch you can make your own with some resistors and a pot, which is what I do for shop testing panels with lots of signals. For field use, though, I use a commercial unit (it is more rugged and looks professional). Some Fluke multi-meters have the ability to generate/simulate the 4-20 as well as read them.
I need some help with scaling an analog input in an MicroLogix 1000 PLC with Analig IO. Its model # 1761-L20AWA-5A. I have more of these...
6,133
Hi friends, I need communication cable PIN CONFIGURATIONS of AB micrologix 1000 analog PLC with PC. I'm willing to create new cable in my hand...
2,343
Hello all. I have a problem trying to read 4-20mA into a Micrologix 1000 Analog PLC. Not sure if my issue is with wiring, or an option within the...
3,513
Here's a tricky problem: I've just finished a program on a micrologix 1000 using a windows 2000 machine, and logix 500 at the house. When I got to...
4,430
Hello friends I am very grateful for the help my post. now I need to regulate output analog 0-10v, with a sliders Rsview32 thank you joel...
1,460
