micrologix 1000 connection problem
Martindag
Sep 2009
quebec
227
hi guys,
im prety new with PLC
my problem is, i got a micrologix 1000 at my job and im trying to connect to it with my laptop it got a module on it DH-485 to connect my cable 1784 PCM5/B and i got also my micrologix cable. i try to configure my driver i had then all already configured and even on other web site they configure it the sameway.... but whatever the COM i use i cant connect to my plc. why is there a date on my plc cable also saying 05/2004 can my cable be expired or something ? lol
here a printscreen of my setting driver also
Almost the same problem.
I have USB-1761-CBL-PM02 cable, ML1000 1761-L16BWA(SER.E, FRN 1.0). Soft: RSLinx Classic Lite 2.51.00.21, RSLogix Micro Starter Lite 8.10.00.
My problem occurs when I tried to do an "autoconfigure". After that my computer gets stuck. What I did wrong?
Any help is much appreciated!
I have been down this road although it has been a few years because I stear clear of these issues. I'll give you a little of what I have done from memory.
First, the serial cable that comes with a ML1000 does work when it is connected to a PC with Linx and the "PIC" driver, but they strongly advise not to do this because of possible damage.
Next, there was an interface that became available when these were new, called an AIC+ and it does work, but it still required a "PIC" driver. The problem with the PIC is that windows does not respect the original PC Serial port design and the PIC came before Windows, so the bottom line is that the PIC has to own the serial port and windows does not like that. In order to get the PIC to work, the PC has to be rebooted so that the PIC can steal the port before Windows tries to take it over.
If you do this, do not expect anything else serial to work on the PC until you de-install the PIC in Linx and reboot. At that point, the PC should return to normal.
Since all that "stuff", another interface became available called the UIC which uses a USB port and it has it's own Windows friendly driver in Linx. The UIC has an RS232 port and RS422 port.
I have both of these things and I got to playing around with them in several configurations and I discovered that there is more than one way to set them up. In one application, I needed the AIC+ to get to a PanelView so to program, I connected it's serial port to the serial port on the UIC and it worked perfect while the other was working to the ML1000. The RS422 port on the UIC can work to the port on the ML1000 also which is great because it avoids the PIC driver.
One last, but very important point to remember when you forget all the rest that I have told you. When you use that serial port setup screen shown in your screen dump, It may not actually place those parameters into the serial port configuration. So that means that you can be flying blind and not know it.
The solution to this problem is to go to the "Device Manager" and find the port configuration popup and do the config manually there.
I wish you success. Once you get past this "stuff", the rest is pretty easy. And the ML1000 is a great box. If you go to americansensors.com and look at the systems, I wrote all of the first generation applications of those systems into a single ML1000 Analog application.
It was full, but they all worked perfectly with a few software switches to alter the configuration of the measuring systems.
Best Regards,
Bob A.
Hello everyone 1st post here. I have a Panelview C400 connected to a micrologix 1000 using a 1761-CBL-PM02. I need to connect my computer so that...
1,646
Hello everyone. I'm fairly new to PLCs. I took some programming classes in college back in 2000 and haven't done a whole lot with anything other...
3,009
Would you please tell me the wiring connection between PC and Micrologix 1000, as well as the type of connectors required?
3,910
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
146
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,262
