Micrologix 1100 1763 analog input
onesparky
Sep 2008
PA
Hello to All
just got hold of a micrologix 1100 1763 unit and i want to use 0-10volt input, for level control, 0 mt and 10 full, when full turn on a pump till mt then turn off. which input to use and do i need to scale? Or how would you recommend it be done?
If using the build-in analog inputs on the base unit then the addresses are I:0.4 and I:0.5.
I would scale the raw data to engineering units something humans can understand. Then use compare type instructions (equal, less then, greater then) to take any action desired.
I would be careful trying to do something at zero/full scale though. Most transmitters do not have perfect zeros/full scale. ( a little high or a little low). Your system may vary.
Thanks to ALL
Thanks for your input I didn't think about the grtr and lstn but it make s sense :)
l8tr
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
148
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
545
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
199
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,198
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,418
