Micrologix 1100 Analog inputs
kingj
Aug 2008
Glasgow
I am a beginner with PLC's and I am trying to make use of the Micrologix 1100 to input voltage and power measurements from a simulator on analog signals and trigger a switching pattern based on the values of voltage and power.
I am using the RSLogix 500 Starter version and I am not able to figure out how to address and collect data from the analog channels. I know that the Starter version supports only 10 points, I wanted to know if it supports the Embedded Analog inputs. If so, then are channels I:0.4 and I:0.5 the analog channels?..
Your help will be much appreciated guys.
Thanks in advance.
kingj
If it is the free RSlogix500 for the 10 point ML1000, I don't think it will work with the ML1100.
No Bob its not the free version. It is a licensed version. And i tried some small logic like the motor control and some switching logic online. It works fine.
kingj
I just have a quick question on this processor. I am making a project with 18 analog inputs so I bought 4 - 1762-IF4 expansion cards and the plc...
1,537
Micrologix L16BWA It has two built in analog input ports. How do I change the input type and range? current/voltage, 0-5v, 0-10v, 4-20ma, etc...
3,907
I bought a MicroLogix 1100 Series B processor off of eBay a couple of years ago ... the digital inputs and outputs worked fine ... I never tried...
2,310
i have a pt100 4-20ma is the analog input on micrologix 1100 only for 0-10V ?? 🔨
3,646
Hi! I'm kind of new to PLCs and I'm learning basics on MicroLogix 1100 with RSLogix Micro software. I want to write simple program to create...
5,957
