micrologix 1100 and encoder
hounddog
Jun 2003
79
Have done a couple of projects using a omron cqm1h plc and absolute encoders so that you would be able to know the position of something when it stopped, etc....
Have never done this with a ab plc, have only used incremental encoder since it was not important to always know the exact position of something at all times if you stopped and restarted the process before the cycle was complete. Could someone give me guidance on how you could do this with a micrologix 1100 plc? Examples, etc... Thanks
On the omron cqm1h plc's that i used it had a special I/O card that you used for the grey scale encoder, if the ab 1100 is not the correctl plc for this, would the 1400 or 1500 work, or stay with a omron.
It really depends on the specific encoder, its wiring, and what you may have expected of the system. If the wiring is standard input voltages then a DC input card would be fine. If the GCD command is not available, Gray to binary conversion is not difficult even with standard instructions.
The omron encoder that i used was a E6C2-AGC and the plc had a absolute encoder port, is there anything like this for a ab plc. If so, could you possibly post a sample program, that would be worth a lot. Thanks
The number E6C2-AGC doesn't seem to match a model with Omron. Do you have a link to information on this specific item?
Attached is a file showing the GCD command and the equivalent ladder code.
Apologize for the delay, had to make a emergency trip to el salvador to work on some dye equipment. Here is the model number of the encoder that i used on omron.
E6C3-AG5C-720
CQM1H-ABB21
This is the omron inner board that you can order for the cqm1h plc, not sure if there is anything like this for the ab plc of micrologix line or not
That's apparently a 720 codes per turn encoder. After performing the Gray Code conversion you will have to subtract 152 from the result to get the final count.
Thanks, that is what I have done with the Omron PLC's using the absolute encoder inner board option.
It appears that the only way you can use a absolute encoder with a AB micrologix series plc, is to use multiple inputs. Does anyone make a input card for the micrologix series that you can connect a absolute encoder to?
Has anyone interfaced an analog encoder to the analog inputs on a Micrologix 1100? I'm thinking about using an absolute single turn rotary encoder...
5,734
question. If you take a micrologix 1100 and connect a encoder to the high speed counter input, how could you then take that value to know the rpm.
2,778
Some info: carton packaging machines, speed up to 150RPM or 2.5 per sec.(linear speed 0.5m/s ) , scan time around 20ms. So far I’ve been...
6,636
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
158
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
560
