Micrologix 1100 and PV600
Earthscape
Sep 2011
PNW
86
I'm being asked to integrate a fairly simple solution, but haven't programmed a PLC for years from scratch. I'm using a ML1100 with a PV600 for the HMI display. I have one analog input, 0-5 Vdc range, and that is literally it. No expansion slots, no cards, just the base. I'm going to use 1 of the two onboard IA's for the xmtr input.
Before I get too involved in asking questions, I wanted to know if there was a document or a tutorial somewhere I could use to help while I re-familiarize myself with all of this ? I just need to set up this one analog point, add a counter and a reset function to the HMI.
Thanks.
See below for links to the ML1100's manuals.
What is the complete catalog number of your PanelView?
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1763-rm001_-en-p.pdf
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1763-um001_-en-p.pdf
And here is a recent thread about the ML1100's base unit analog input.
http://www.plctalk.net/qanda/showthread.php?t=66525
Thanks for the reply. The Panelview part number is ; 2711C-T6C.
I'll take a look at these manuals.
The 2711C is a "Component" PanelView terminal, built specifically for use with MicroLogix family controllers. The editing software is either accessed using a browser or by using the "Connected Components Workbench" launcher.
The PanelView Component "Quick Start" document is a good place to start:
http://literature.rockwellautomation.com/idc/groups/literature/documents/qs/2711c-qs001_-en-p.pdf
Thanks Ken, I think that part will be a little easier. Its just been years since I've programmed a PLC, and when I did, the apps were DOS based. I sincerely appreciate the help.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
152
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
553
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
205
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,205
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,432
