Micrologix 1100 & FMS Ethernet/IP
Gomez_
Sep 2014
California
195
Hello,
I'm attempting to connect the 1100 to an FMS CMGZ309 EIP Tension Controller using the MSG command.
From what I can tell It should support generic CIP messages, but all of the setup instructions are for a RS logix 5000 style PLC.
I have attached the EDS and here is a screenshot from the manual:
My main goal is to read from the Input assembly (which has the tension values)
Secondary goal would be read and write to the config assembly.
Should I use the standard "Read assembly" service?
Should I use a custom service?
My attempts so far have all resulted in errors:
Thanks,
Gomez
I figured out my issue! Everything was configured correctly in the message, except FMS added another parameter so my size was too small for receiving the data.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
125
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
196
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,196
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,409
