Micrologix 1100 For Hands-On Projects
amenyo
Jul 2012
Arkansas
23
Belated Merry Christmas and Happy New Year to all. I wish everyone well for the new year.
I bought a Micrologix 1100 processor (1763L16BBB) to use for some hands-on projects at home and 4 of the 6 DC outputs are Field Effect Transistors (FETs). I have read a few posts to the fact that when FET outputs are used to control lamps for example, they tend to not switch on and off as intended. Does anyone know of any problems with FET outputs? On the other hand, what advantages do FET outputs offer over Relay Outputs apart from the fact they do not have any moving parts and tend to last longer? This is not going to be used for industrial application. Thanks for any information anyone is able to provide and thanks for everything all of you continue to do on this forum.
Sometimes you need to make sure you have a load on them or a large enough load to make them switch if your load is to small then just use a small resistor with the load and you will be fine, I have not found any issues with "control lamps" (like with my trainers) but in the early days I did notice some with LED's as I think they did not have enough draw on them
They are faster then relays and will not go bad if you are cycling a lot... but when they do fail then tend to fail closed, I would prefer failing open.
They can short out easy if not wired correctly or just shorted for a nano sec :) I hate when that happens
So check the current draw on the load if to much then use a interposing relay as they cannot handle much of a load then you should be fine, they are great little CPU's
I appreciate your explanations. I think I will be better off with a processor that has isolated relay outputs rather. This is the first trainer I'm building and I will hate to damage over $300 processor because I fail to add a resistor with the correct rating to a load. Thanks for input.
if you already have the PLC, i would just wire the outputs directly to relay coils for a trainer. Then you don't have to worry about shorting out PLC outputs, output voltage, or relays getting welded. If you mess up a relay, it is quickly and cheaply changed out.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
196
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,196
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,408
