Micrologix 1100 HSC external reset
kolyur
Oct 2004
Wooster, Ohio
1,602
I'm using a quadrature encoder (A,B,Z) with a Micrologix 1100. The counting is working fine, but is there anything I need to do to enable the external Z reset? I have the HSC configured for mode 7, "Quadrature counter (phased inputs A and B) with external reset and hold" but it doesn't reset. The Z signal is wired into I:0/2 as required and I verified that it pulses once per revolution.
OK I solved this problem by using an Event Interrupt (EII) to reset the HSC accumulator whenever the Z signal goes high. Not sure if that's the best way to implement the external reset, but it seems to work fine.
Hi all, Just wondering if someone could confirm/clarify something for me regarding the high speed counter on the Micrologix 1100. As I...
2,793
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
149
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
545
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
199
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,199
