Micrologix 1100 output not responding
Take it all apart, reseat the connections, re-read the IO, download the original program, double checking everything.
Sounds very frustrating!
Very frustrating. Luckily it's not a very big program so I could setup a new program and just re-do it on this PLC.
I'll try and take everything apart first and hopefully it just decides to work.
Instead of hitting re-read I/O I went to advanced properties on the modules and selected ignore configuration error and now it works... No idea...
Are the red and black wires in the image below the right way to drive a 0V or 24V discrete output signal from a O:0.0/2 of a MicroLogix 1100...
862
Hello all, I don't get the chance to use the Micrologix much anymore and have a question about PID output limiting. I am limiting in the PID, the...
2,493
I'm building a model traffic light with my Micrologix 1100 processor (1763L16BBB) and two of the lamps that are controlled by relay outputs are...
3,881
I am trying to put together a program for a control valve and scale combination. I will be using a ML1100 PLC, a 1762-IF4, and a 1762-OF4. I will...
9,626
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
127
