How to hook up MicroLogix 1100 FET discrete output
drbitboy
Dec 2019
Rochester, NY
8,106
Are the red and black wires in the image below the right way to drive a 0V or 24V discrete output signal from a O:0.0/2 of a MicroLogix 1100?
Also, do I have the right behavior described for the voltage at the blue x?
If yes to both, then I am pretty sure this is a sourcing output. Do I have that right?
I realize the design of the load will also need to limit the current, but I am more interested in getting the wiring right for now. Also, I realize that 0V and 24V are nominal, and the actual signals might not be exactly those levels because O:0/2 uses a FET.
The base diagram is from the ML1100 Installation Manual here.
I understand Ohm's law reasonably well, but I am definitely weak when it comes to terminology and jargon of DC. After a while I finally realized (I hope) that "DC 24V-" is an alternate expression for "COMmon" i.e. the low side of a 24V range, and is not the same as "DC -24V" i.e. a voltage 24V below a ground level voltage.
There is an old thread about a similar task here. The OP in that thread mentioned connecting the COM and the GND, but I am guessing it would also work if the DC 24V- IN and the O/2-O/5 "DC 24-" (DCc) were isolated from the ground (⏚).
Sorry for the basic questions, but I could not find anything that laid it out like that: the base diagram does not show +DC IN and -DC IN connected to +DCc and -DCc, respectively. That is probably obvious to everyone, and they are not connected in the base diagram because the designer may want to supply an external voltage source to +DCc and -DCc, but it was not obvious to me.
Thanks.
All looks good to me, it is basically the same as transistor output units, I also agree with connecting the V- to the ground all the panels I have built I do this.
However, I would put in a breaker or fuse feeding the output supply the PSU will probably be something like 4-10amp depending on your supply requirements so perhaps a smaller fuse/breaker feeding the +V common of the outputs to protect them from shorts. Some people fuse the outputs individually but that is a matter of choice.
Yeah looks fine to me, Parky's comment about fusing is a valid one even for testing, very easy to accidentally cook something and those FET outputs are sensitive (I've blown a couple on a 1400 once by not paying attention ).
24V comes out of the output terminal for logic state 1, as you've drawn.
What kind of load are you driving?
Thanks @parky, @Saffa. I mainly want to avoid letting the magic smoke out.
It's for my home lab: the power supply is the charger of a defunct laptop. I am hoping to drive this servo via PWM.
That fuse is a great idea; thanks for that too. As you are probably aware I am usually programming with internal bits (B3/n) as proxies modeling real I/O; moving external electrons requires a different, more careful, mindset*.
TL;DR
Eventually I hope to replicate @geniusintraining's ball and beam device. The code is more or less written in my head, although I will be coding the PID equation also, as I am too cheap to buy RSLogix 500.
The next step will be figuring out how to get the 24V PWM signal down to 4.8-6V; from my reading that servo should take its motive power and current across the other two wires (gotta figure that out too; I think four AAs might do the trick), and the PWM positioning signal will be low current.
Thanks again!
* I did once manage to make some sparks by poking a wire from DC 24V+ briefly into the grounded DC COM terminal instead of the input terminal next to it as intended. Apparently the laptop charger has a current limiter that dropped the voltage; the PLCs rebooted after I jumped back. It's good to be smart, it's better to be lucky. Now there is a piece of duct tape over the DC COMs (Fool me once, ...).
Good Afternoon , I'm working on a project , and this project has a fairly large control panel with a 1769-L33ER processor. I would like to...
1,639
Hi all, Where I work, we make a lot of hydraulic power units with three phase motors. We test each of these and so are constantly hooking up...
2,690
Can anybody please tell me why SCADAlarm 6.0 gives massage in system status like "An I/O device used by SCADAlarm failed" and in main window...
1,735
Hi All Teki Friends I'm a Instrumetion engg. working on siemens plc. But today my question is some wat different. It is related to field...
2,709
I need to know what the the comm cable connections are (9 pin etc.) and I have the rslogix5 program for the computer. need in a hurry please...
1,773
