Micrologix 1100 / Panelview 400 Ethernet Problem
Do you have an IP address set on the PanelView?
Do you have an IP address set on the Micrologix?
Are you connecting with a crossover cable or a switch?
You have to provide more details if you expect to get some answers.
I have the same problem. The Ip adr is config. 100.1.1.12 in panelwiev and 100.1.1.13 in the slc. I am connecting via a switch
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
892
Hi PLC People, I get the following error when trying to compile a Panelview Plus 7 Standard program Using View Studio V10.0 Device Shortcut is...
4,871
Hello Everyone, I am a college student at the University of Wisconsin-Platteville. My professor is having me integrate a Panelview 800 HMI into...
6,905
Hello, I am currently installing a PLC control panel and due to space constraints, we will need to install the Panelview 600 HMI separate...
3,380
I'm trying to program a Panelview Plus 600 for a Micrologix 1100 using ethernet. I have set the PLC address to 10.188.13.60 and the Panelview to...
7,954
