Micrologix 1100 to micrologix 1200 connection
Afrasyab
Jan 2016
Derby
Hey everyone!
I have got 4 micrologix 1200 plcs which are already programmed in rs logix 500
Now I am trying to write a ladder program for micrologix 1100 so that I can read the data from 4 micrologix 1200 plcs and check their status
Any suggestions from where should I start?
You'll have to network them first. Since the ML1100 has Ethernet capability, I would use serial-to-ethernet converters (like Digi One IAP) to make a small ethernet network. Use the MSG instruction pointed to a particular IP address to read data.
BTW, you can set up a single IAP to connect two serial devices to a single physical ethernet connection. Consider this option if the ML1200s are fairly close to one another
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
534
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
194
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,195
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,408
