Micrologix 1100 to PC ASCII communication
zmedina
Feb 2011
Chihuahua
I'm new at ascii comminucation and I have a Micrologix 1100 that I need to setup to be able to write and read ascii characters to and from a PC.
I've already set up the channel 0 configuration to ASCII but:
what baud rate should i use?
what kind of serial cable should i use?
Do you have a program example?
Thank you in advance.:)
Baud rate depends on what you are talking too.
You may need a null modem adapter.
Serial Cable is sold by AB with the mini Din to 9 pin 232.
I have most of mine set up as
Baud 19200
Parity None
Stop Bits 2
Data Bits 8
Term1 \d
Term2 \ff
No handshaking and ignore
I was able to set the baud rate to the scales i am talking to and the rest of the stuff is what the scales wanted.
It helps to have the comm configuration manual for the machine you are taling to.
Hi Guys, i am reposting this beacuse I'm still having issues with the "READ" ARL or ARD instructions. I have a pdf of a program that I found on...
1,972
Hello, I am working with a micrologix 1100 allen bradley plc and I need to send and receive ascii code to a sensor device. The syntax for the...
2,313
I'm using a Micrologix 1100 and I want to add a sensor that has a RS422/ASCII output. The sensor outputs a series of messages in hex format over...
1,471
Hi all, i got some problem about i think some configuaration in mine micrologix1100. I try to write some string (ascii) via serial com to some...
2,274
Hey everybody, I have two Micrologix 1100 connected via a serial cable between the two 9pin rs232 ports. I am trying to send a simple ASCII...
8,589
