Micrologix 1100
shoelesscraig
Apr 2009
LA
382
Quick simple question (I think)...
I have a ML1100 that already has an Automation Direct HMI connected to the 9pin (round) serial port on the side. I was wanting to connect a bar code scanner to this PLC, but I assume I cannot since the serial port is already used for something else. Just wanted to make sure I'm not missing something before I decide this cannon be done (without buying some new equipment).
This is my first ever dabble in the world of bar code ASCII, so I figured I should ask just to make sure. Thanks ahead of time.
Which AD HMI are you using? Does the HMI have another port? It could read the barcode and then send it to the PLC, or process it in the HMI. I don't know if the AD HMIs can do this but I've run barcode readers through Redlion HMIs a few times.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
132
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
540
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
198
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,197
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,412
