MicroLogix 1200 Communication Toggle Button
sooner
Jun 2021
Kansas City
I don't have any prior experience with MicroLogix so the Communication Toggle Button is new to me. We currently have a few MicroLogix that are using the RS 232 port (Channel 0) to communicate to the HMI. I am needing upload from the PL C to make a slight modification to the program and download it back to the PLC.
The PLC is currently not communicating with me through my Serial to USB converter cable. I have read and found out about the Communication Toggle Button that will allow the PLC to flip back and forth from the User-Defined configuration and default configuration of the communication port. Once I toggle the communication button to default and am able to communicate and upload from the PLC, make my change and insert it back into the PLC, am I able to simply just toggle back the communication button so the PLC will communicate with the HMI as before through whatever protocol it was using before my change? Will it still revert back to the user-defined communication protocol?
Yes, that's exactly what it does.
When you press the DCOMM button and the DCOMM LED turns on, then the Channel 0 serial port is set for the default DF1 settings (Full Duplex point-to-point, 8/N/1 framing, 19200 baud, CRC error checking).
If you press the button again and the DCOMM LED extinguishes, the controller goes back to whatever settings the user program was configured to use.
I ran into this issue, too, a couple of weeks ago. Where is this DCOMM button? Next to the 8-pin mini din?
I ended up disconnecting the HMI, and plugging that HMI cable into a UIC adapter, to get online with that ML1200 PLC. Found out the channel 0 port was set for DH485.
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,805
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,619
Hello All, We have a MicroLogix 1200 series controller on a package in our plant. We need to connect a serial device to MicroLogix 1200 for...
4,632
Good Day All, I've a MicroLogix 1200 and Panel View 300 Micro installed on a package in process and its working fine. PV is connected with 8 pin...
3,618
Hi all, new user. New to PLC's aswell. I am struggling to programme a Micrologix 1200 series C (L24BXB) to communicate with a serial slave...
1,941
