Micrologix 1400 1766-L32BXB SER.A REV.A
AlecTek
Sep 2010
Vancouver
155
Does it have Ethernet port and support Modbus TCP?
I was told Ser. B would support but not A. But not sure where to find the documentation.
Thanks for any help.
Just checked the manual- you need Series B to do Modbus TCP. You can check Rev A's functionality by creating a new offline project for a ML1400 A and seeing if the modbus table exists in the channels tab. It shouldn't be, but switching to B should open up the option.
This is correct. The series A would support Modbus RTU on either serial port, but not Modbus TCP.
Both series A and B Micrologix 1400s have Ethernet and two serial ports.
This is mostly correct except you would look on the Channel Configuration tab for Channel 1 to see if there is a tickbox for Modbus TCP present. The tables would appear for Modbus RTU Slave protocol on a serial port.
Channel 0 - serial RS232 or RS-485 round micrologix DIN connector
Channel 1 - Ethernet
Channel 2- RS232 serial port with DB9M connector.
Hey I'm a student working on a project. I trying to control a 0-10V driver using the analog output on the ML 1400. To test and output I've been...
26
9,414
i need to configure a linear transductor Balluf 1300 mm at the analog input IV0. I need a sample program. Help me please.
2,104
Hi guys, I am going to configure a diesel engine rpm monitoring on the 1766 micrologix 1400 controller using the build in HSC input feature via...
4,971
45
101
