micrologix 1400 and 1762 if4
heroek
Jun 2013
italy
Dear Sirs,
i have a problem with my micrologix 1400 with analog input 1762 if4 .
I have set the hardware jumper for Volt and i added the module 1762 to rslogix micro configuration as in picture .
But i don't see nothing in the input table , all zero instead of a value .
What can i do ?
Hi Need help. I'm new to the plc progamming specifically Allen Bradley PLC. I am planning to create a control for an oven. using Micrologix PLC...
2,520
Hello All I have an application using a ML 1400 with 4 analog inputs and a 1762-IF4 expansion card with 4 analog inputs. I have 6 analog...
9,928
41
101
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
225
