Micrologix 1400 communication with RSView 32
nilesh_1106
Dec 2011
pune
34
Hi Everyone,
I am new to RsView32 SCADA. I want to configure the RSView32 with Micrologix 1400. I tried for communication between of them but I was not able do that.
Let me know, how to configure the channel & node in RSView32 for Micrologix 1400 (As I am using DF1 protocol for communication).
Is the RSView 32 already collecting data from other PLC's and if so by what method
Have you read the manual inclded with RSView 32 that guides you in setting up channels and nodes and comms in general
there are only one PLC & I was already read the manual but theare are no information for Micrologix series PLC communication. As in node setting ,micrologix node was absent (I am using Direct Driver Method).
So I am not getting how to do the communication between them?
there are only one PLC ?
Does this mean there is already one exisying and you want to add a second
RSView requires a paid for version of RSLinx
that means that RSLinx Lite will not work for you
What version numbers do you have for your software RSView 32 And RSLinx
What windows operating system is your computer
Tell us as much detail as you can because one question and one answer at a yime is not going to be much help to either of us
Hello, I'm working on a project in which I need to communicate a Micrologix 1400 series C to a Zebra printer ZD230t through Ethernet/IP. Is there...
754
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,198
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,521
Hi, I am trying to communicate between a MicroLogix 1400 and a Click PLC. There is a great video from AD that shows the simplicity of...
1,780
Hi there, I am trying to communicate between Siemens 1214 that I have and a Micrologix 1400 on the other end through CIP protocol. I downloaded...
2,068
