Micrologix 1400 FET output
sanchezcr
Jan 2020
Heredia
Hi. I bought a Micrologix 1400 to run a servo with its high speed output. Problem is that the output is +24VDC and the drive HSI is 0VDC. How can I generate a 0VDC output to activate the drive?
Hi: I have the "all DC" MicroLogix 1400 (L32BXB) and would like to connect small relays and LED lights to the onboard FET outputs. Of course, the...
6,454
I have a project I want to do with a ML1400 [1766-L32BXB Ser B] listed as having relay outputs. However 6 of the 'relay' outputs are FET outputs...
6,193
I have an AB Micrologix 1766-L32BXB which has 6 FET and 6 relay outputs. My problem is that I just noticed that the solenoid valves (ten total) I...
6,081
45
101
