Micrologix 1400 IP address
RJ29
Dec 2019
INDIA
25
Hello everyone,
i have a micrologix 1400 PLC, i set its ip address using the LCD screen provided on it, but everytime i the PLC is power cycled it loses the ip address and i have to configure it again. I have disabled dhcp and bootp in channel configuration by going online but the problem still exists.
Is there a 1766-MM1 installed? if yes then you need to write the program to the MM1 or it will be set to the MM1 settings every time the cycle is powered
Hello everyone,
What IP address are you trying to set in the ML1400?
If your trying to use APIPA (Automatic Private IP Addressing) - address in the range of 169.254.xxx.xxx it will be looking for the presence of a DHCP server.
I'm not trying to set any private IP address , the address is 192.168.1.101
Hello, I was wondering if there was a way to be able to change the IP address on the Micrologix 1400 through an HMI screen (say a panelview 800)...
1,621
Hi friends, Please share if you know whether I can change the modbus address of the PLC programatically (maybe by writing to S15). Appreciate...
1,006
Hey everyone, i have a very very stupid stupid question. How do i change the IP address on Micrologix 1400 using Rslogix 500. i know how to do...
3,891
Hello, I am trying to configure an IP address for networking my MicroLogix 1400 to KepserverEX. I am using a bootp/dhcp server to configure the...
4,635
Hey this is my first post on here. Im using a micrologix 1400 for the first time, I'm just having one issue which is when I fully turn off the...
5,271
