MicroLogix 1400 Messaging Breaks
Sean Teague
Apr 2020
Tennessee
69
Hello all. I am working on a program that is using a Micrologix 1400 communicating with a Keyence SR-1000 barcode scanner over ethernet.
Everything works as it should, but if I go offline and do anything at all, I.E. add a new ladder, add a new type of data file, even if I just expand the elements in a data file (adding more bits or timers to an existing one), the messaging breaks.
I cannot get the messaging working again, even if I go back and delete the ladder or elements i had just added and re-download again, messaging stays broke.
any ideas?
What version of RS500 are you using? Version 10 has a bug where it would screw up messaging instructions upon download and you could only get them to work by deleting and rebuilding the instructions. There's a patch (of course, it's AB!), or just use version 9 or 11.
Best part about the bug is it would randomly affect messages. Some would work, some wouldn't.
Welcome to the PLCTalk forum community !
Can you describe the error messages or other symptoms of how the messaging is "breaking" ?
Post the *.RSS file (ZIP it first) if you can.
Corruption of a MSG control file by an edit of the MSG instruction isn't unheard of, but changes to other logic absolutely should not interfere with the functionality of MSG instructions.
I know there have been several posts on this subject but... Is there a best practice for setting up multiple messages in a Micrologix 1400? I've...
4,551
Hello everyone, I'm having an issue trying to get a messaging instruction to work. I'm trying to get some data from a Micrologix 1400 to a L83E...
18
6,190
Hi all, I am developing an application at the minute using a Kinetix 300 and a Micrologix 1400. The servo must follow a shaft on an existing...
10,093
I have a Micrologix 1400 that needs to read & write a few integers & reals to three SLC5/04's that are connected via DH+ network. To bridge the...
8,230
I am new to using the messaging system on this PLC. I have successfully connected 2 of them and used the Msg Read and Msg Write to exchange data...
2,742
