Micrologix 1400 PTO outputs
RobertB
Oct 2017
WI
78
Hi, I can't seem to find a thread on this, so I'm starting one.
I want to use 2 PTO outputs off a BXB 1400 Micrologix series C. BUT... I need the peak output voltage of 10- 12 vdc. Can I just bring in 12vdc to the Group 2 Outputs.... or do I need a voltage divider downwind of the 24vdc outputs.
I would like to keep this simple.
Thanks in advance!
That's a great question !
I think that the high-speed output circuits that serve Outputs 2,3 and 4 on a MicroLogix 1400 are designed only to work with 24V +/- 10%, so your voltage reduction is going to have to be done with a level shifter or other downstream circuit.
There is a Knowledgebase document (ID: QA20637 | Access Levels: TechConnect) that explicitly repeats that question:
Can 12V DC be wired to VDC2 to get the FET Outputs work properly on 1766-L32BXB?
And the answer is a restatement of the 24V power supply specification.
Hello Everyone, I have a new project that I will be working on over the holiday break and have never done a stepper before I am using a...
2,889
I currently use a Jog Continuous at 5000hz successfully. My application requires a two speed blended jog now. I need to start the jog at a...
2,596
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
45
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
107
138
