I have an application where I need to put a Sick CLX490 in "Sleep Mode" and put it back into "Run Mode" (Laser On) utilizing the ASCII AWT command. You do this by the following Hex Code.
Sleep Mode = ASCII 13 (02313303)
Run Mode = ASCII 11 (02313103)
My issue is I know how to use the AWT command, but do not know how to properly enter the data into the string so the scanner interprets it correctly. Can anyone help?
