MicroLogix 1500, ASCII instructions
Bmoney
May 2009
Richmond
Hello Guys\Gals,
I am trying to write to a simple display from my Micrologix 1500 processor's serial port. (LRP, so I have 2 channels, the channel I'm using is configured for ASCII).
The display requires a string of the form <SOH>string<CR>. I can place the string into a string data file in RSLogix500, ST9 for example.
I can use an AWA instruction to append the <CR> control character, however I do not know how to send the <SOH> control character before the string. From talks with Rockwell, it sounds like if I put a ^A in the string, it will not be interpreted as a control character but rather as just a part of the string. Rockwell suggests that there is no way to add a control character before the string with a ML1500.
Do you know of any work-arounds or have any suggestions? Thanks!
Try the ACN instruction. I have several serial label printers controlled by ML1500s, and I use this to build the data string to send to the printer.
For example:
ST9:0 will equal your control character <SOH>
ST9:1 will equal your string
ST9:2 will be the destination of the result
After you execute the ACN the destination should contain: <SOH>string
If you repeat this with ST9:2 and a string that contains the <CR> into antother destination you should get <SOH>string<CR>
I hope I explained this correctly.
/Shrug, I just tried it here, using ^A works fine. Make a single string with the "^A" combination, it should show a length of 1. If the combo were interpreted as 2 characters, it would show a length of 2.
Now, just use ACN to combine that, and your "Send String" into another one, append the CR, done.
Ok. I will try what you two have suggested. Another question that I have is that the display is set for 8 bits per character and 1 stop bit. I have seen how this can be configured in other processors, however I do not see any options for this in the ML1500 ASCII setup.
Any thoughts?
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,431
Hello, I am a veteran Mitsubishi programmer, but am new to AB. I have a Micrologix 1500. I am receiving a string via RS232 on Channel 1. In...
5,010
I have an application where I need to put a Sick CLX490 in "Sleep Mode" and put it back into "Run Mode" (Laser On) utilizing the ASCII AWT...
2,278
I am trying to use a ML1500 to communicate with a barcode reader via ASCII protocol. It isn't working, so I tried to verify the reading/writing...
5,241
Good Morning all, I have what may be a simple problem that is causing some major headaches this morning. I am trying to integrate a Zebra...
6,791
