Micrologix 1500LSP, Ethernet HMI and RSLogix simultaneous
ssilk76
May 2015
NE Indiana
I have and AB ML1500 LSP (DF1 only) and a AB C400 hmi (Ethernet), will the DIGI IAP allow the 2 to communicate and allow RSLinx/RSLogix access at the same time? Or... Does anyone know of a solution that is known to work in this situation?
I might need to clarify. Net-eni only supports 2 read/write connections at once and I don't want to leave myself in a position where I cannot expand. If I have the C400, the ML and RSLogix then I cannot add any future ethernet devices including my SCADA system (ignition) and PLC-PLC communications. This is why I do not want to use the ENI.
36
87
99
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
136
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
