Ones_Zeros
Hey guys I 'm having problems getting a valve to move that has a DVC6200 actuator connected to it via a MicroLogix 1762-OF4 PLC card.
I can move the valve with a 789 process meter at the valve or on the same wires before connecting them to the PLC.
Here is a pic of the DVC6200 actuator that I'm wiring the PLC to. It shows how the DVC6200 should be wired to the PLC.
I have change the PLC 1762-OF4 card to test to make sure the card was good.
What would you guys recommend first?
1. I have supplied 24v loop power.
2. My thought was if I can move it with the meter then I should be able to connect the wires to the PLC and type in a valve on the output to move the valve.
3. Can you guys give me some advise/direction on how the wiring should be just so I can double check myself?
I appreciate the help!
