MicroLogix Error 71
IndiaJones
Oct 2007
New England
Long time reader first time poster...
I have a Micrologix 1500 LSP with extended IO (1 IT6, 2 IF4's, 3 OF2's). It has been running fine for a year.
Currently every 30 to 60 minutes I get a fault (71h Communication loss to IO card, not able to determine which one.). Any tips on how to find out which card is causing it, or could the problem be with the processor itself. Any advice would be appreciated.
Could be almost anything.
I would order another BASE UNIT. Check your end cap, located on the last card to the right. (Usually a different message would be indicated for end-cap though).
You are going to have to do some replacing soon I would suspect...
Check your analog devices on the OFxx and the IFxx cards to make sure nothing is shorted. I had a similiar problem with a compact logix faulting after running for weeks, then days, then hours.
That's the issue that I have. I assumed either a short or noise. I disconected all inputs and outputs and placed it in run. 30 minutes later same fault.
So, what was causing the error 71?
Did you find the cause?
If not, how did you correct situation?
I am having very similar problem, checked everything and do not know what else I can do.
Hello, I need help with PLC error code. Major error S:6 = 487h. Which is known for The expansion I/O configuration in the user program did...
2,004
Hello all, I want to get the alarms of extension modules of ml1400. There are S:6 and S:29 system datas. When a module has an error we want to...
2,660
Hi PLC People, I get the following error when trying to compile a Panelview Plus 7 Standard program Using View Studio V10.0 Device Shortcut is...
4,869
A customer asked me if I could reset a fault on their Micrologix 1000 using their Hand Held Programmer. Well... I've never touched a HHP, so I...
2,769
Hello people, it's been a while... Hoping someone here with patience can help me detect a problem with this code. Its a cyclic state machine...
3,227
