micrologix memory size
As most PLC's still assume that memory is allocated in BYTES the answer here is that 1 WORD
= 2 BYTES; 1 DWORD = 4 BYTES.In the classical sense 1k = 1024 (2^10) and 4k is 4096 bytes.
Hence 4k would hold 2048 WORDS and 1024 DWORDS.
This will not give how many instructions the memory can hold as different instructions will occupy n bytes each.
Hope this helps
In the Allen Bradley alternate reality program logic and program data are linked together. Is it possible to update a Micro Logix program with out...
4,473
Hi Guys, Can anyone tell me if it is posible to explain to me whether it is possible to set a Micro1400 Allen Bradley PLC to not allow data...
2,438
We programmed a Micrologix 1500 we had left over. We forgot to insert the memory module. So we powered down, inserted the memory module and...
4,245
Hi all, A client has recently replaced a Micrologix 1200 on site. They installed the old Memory module and expected it to just run but it didn't...
3,748
