Micrologix relay output life
Cryogen
Oct 2005
NH
151
Does anyone know what the life span of the relay outputs are for a Micrologix 1200 (1762-L24BXB)? Where can I find this information? I checked the manual but it doesn't have this info.
Any help would be greatly appreciated..
It depends.
What is your enviornment?
What are you switching? Power or Signal?
What current level are you switching?
AC or DC?
How often are you switching?
No load, simple switching tests generally indicate a MTBF greater than one million cycles for the mini relays used in the micrologix.
The relay output (O:0/0) is connected to a 24V DC, 12.7W solenoid valve. It is being switched about 100 cycles a day.
Now. the life would significantly reduce if a supperssor is not connected.. right?
Hey guys, Quick question. Got a little control panel to build for a hydraulic press. There's about 12 solenoid valves being controlled. From what...
3,748
Any experience repairing or replacing a bad output relay?
3,858
Does this mean it can run 24vdc and 120vac relays depending on which of the 10 outputs are used? Whats the difference from OUT 0-9 and VAC DC...
4,934
I have an issue on a system i've inherited. I had one of my relay outputs sticking on. When the lights off and i'm still getting voltage through...
1,195
One of the relays in a micrologix 1500 has welded shut. It's controling a 24 volt motor starter coil. Can these be serviced? It's in an...
2,207
