Micrologix
Nov 2005
Swansea
Anybody know where i can down load a copy of this plc software and the authorization to use it
having major problems on site and compnay wont send this software
cheers
cheers
Your local Rockwell dealer will cut you a smokin' deal. You'll get the software, and the activation liscence to use it to boot!
Seriously, though, no one here will help you pirate software.
cheers
Depends on your major problems, if its just some simple editing and changing timers then you could get a hand held programmer
Quickest place to get one would be RS if you havent got an account with Routeco or Rockwell see rs part number 191-6928
Other than that youu'll need the logix 500 software and a cable which requires paying for, unless as otherwise staed its an ML1000.
Whats exactly is your troubles with the ML ?
If the company that wrote the program refuse to let you have a copy of the ladder then it's quite possible they have password protected the plc as well, so although there are ways to remove passwords (I for certain will not spill the secrets here) you could be wasting your time paying for the software if you cannot get into the plc.
cheers
Thanx all for your help wasnt really expecting any information on dodgy software anyway just the help you have given is enough for me to go back to the original company and isist they supply cable and password or they send a Engineer at their cost to repair.
As for the problem I have a PFR with a 3 sec delay timer which faults my PLC as the time delay is too long should be a easy fix but manufacturer is being awkward
Thanks again All who replied
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
73
125
122
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
157
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
152
