Micrologix1200 comunication problem
Hi Ken,
I might have made the mistake of posting too much information and making it all sound like nonsense. My apologies.
I have done the exact steps you have suggested doing and the autoconfigure still times out. I have manually configured the setpoint and still have not been able to see the PLC in RSLinx as well as RSWho.
I do not believe it is the cable. I have tried 3 different Serial-USB cables to plug into the 1761-CBL-PM02 cable. One of those cables is a fresh out of the box 9300-USBS.
I do not believe it is the port being damaged on the MicroLogix port because:
1. the port is being used for communication with HMI with no issues.
2. I have tried communicating with 2 other identical machines that we have and run into the same issue.
This is why I think it could be something on my end from a software standpoint maybe?
But I am not sure what it could be.
I have a micrologix 1200 that will run one of three different timing sequence, depending on which input is triggered. I'm trying to find the best...
3,462
How to check the communication between the Micrologix1200 to Citect SCADA. I use PLX51-DF1-ENI router to communicate in scada. I tried to use...
1,351
I have a micrologix 1200 and I am trying to get a barcode scanner to talk to the COM 0 port. I know the scanner baude rate is 9600 because I...
1,785
Good day all. I have a some MAC bullet valve catrtidges (BV210A-CA1-00-BEH0-CTC). They control vacuum for suction cups that pick up various...
1,622
Can I communicate to a Micrologix 1200, going through a Panelview C600? I have this machine made by SIDEL that has a Micrologix 1200 talking to a...
1,495
