Micromaster 440 - Reading values
dana hungary
May 2015
Gyor
Dear all,
We are working with MM440 at th plant where i'm working. The MM440 is connected to S7 400 PLC. In the hw config the setting is 0PKW 6PZD and the addresses are 576...587. I know from the PLC program comment that the PIW576 is the ACM Status, PIW578 is the ACM Freq, the PIW580 is the ACM Current, ect. But what can i do if I don't know these information from the PLC program? How can I check that which value is on which port? How can i set the MM440 if i want to read the ACM torque values instead of ACM status on the PIW578 address? Please help me somebody! Thanks
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,982
fault A0501 (i.e current limit ) displaying whwn i replace siemens 420 drive with mm440. all parameters are crosschecked. please help to...
1,557
I have a Siemens Micromaster 440 (6SE6440-2UC25-5CA1) with encoder module (6SE6400-0EN00-0AA0) and Profibus module (6SE6400-1PB00-0AA0). I'm...
3,067
Hi All I have the SIEMINS micromaster 440 not starting good several times then start after 1 to 2 hours . so I took the AOP kit and opend it >>...
4,464
I am working on converting from a seimens micromaster 440 communicating by profibus to a Schneider Electric altivar 71 communicating over...
1,201
