Micromaster 440 with profibus changing to Altivar71 over Ethernet
jtashaffer
Aug 2009
KY
415
I am working on converting from a seimens micromaster 440 communicating by profibus to a Schneider Electric altivar 71 communicating over Ethernet. I was wondering if anyone has done this conversion? The seimens vfd had a auto status indicator. I need to do the same for the altivar VFD. I am using LI3 as my logic switch for auto. It is a hand/off/auto setup. Does anyone know what the scanner input address would be for LI3 when it is switched on.
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,975
I am getting a fault code F0022 (2) on the drive. Has anyone ran across this.
4,197
Hi All I have a project with a MM440 drive on profibus. What I would like to do is select it into two modes of operation via a selector switch...
2,555
Hi, I have an intresting problem: I replaced a mocromster vector drive with micromaster 440 which was running on profibus. I made the hardware...
2,594
Hello all, We have a MM440 and 2 limit switches and one rotate encoder. And the MM440 is on profibus-dp. The encoder will tell the position so...
2,268
