MICROMASTER 440 + profibus + encoder + limit switches
AlecTek
Sep 2010
Vancouver
155
Hello all,
We have a MM440 and 2 limit switches and one rotate encoder. And the MM440 is on profibus-dp.
The encoder will tell the position so we could control the motor to stop at any place (no need to be accurate) through profibus, while the up and down limit switches are the protection.
Also I would like to have the down limit switch to be able to use as the home switch ( i.e. zero the encoder counts)
Does anyone know if this will work?
Best regards
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,979
I am working on converting from a seimens micromaster 440 communicating by profibus to a Schneider Electric altivar 71 communicating over...
1,201
I am getting a fault code F0022 (2) on the drive. Has anyone ran across this.
4,198
Hi All I have a project with a MM440 drive on profibus. What I would like to do is select it into two modes of operation via a selector switch...
2,557
Hi, I have an intresting problem: I replaced a mocromster vector drive with micromaster 440 which was running on profibus. I made the hardware...
2,595
